Originally published at: Azure Healthcare Data HUB with Mirth Connect - Open Integrator
This is a draft post without content currently. Hoping that someone would implement and write about how to install Mirth Connect on Azure in a load balanced way and move HL7 and DICOM content through it and then do the same with Azure tools and compare the results. As a starting point, this article by…
