DCM4CHEE Archive 5 Tutorial Series
In this topic I will publish tutorials for DCM4CHEE.
Please comment on which features are you are interested in.
Episode 1 Login & Study Search Basics in DCM4CHEE Archive 5
Here is episode 2 showing how to upload dicom files and also how to download them from the DCM4CHEE archive user interface.
In episode 3 you can see how to delete studies from the DCM4CHEE DICOM archive.
Episode 4 released
I show you how you can move a study from one patient to another in DCM4CHEE Archive 5. This can be used for example in a situation when the user selected the incorrect modality worklist entry or manually entered the incorrect patient.
Episode 5 released
I show you how you can split a study in DCM4CHEE Archive 5. This can be used for example in a situation where we had two patients in a row and we by accident send all the images for both of those two patients to the first patient.
Episode 6 released:
In this step-by-step tutorial, I’ll show you how to query and retrieve DICOM studies from a DCM4CHEE archive using the Mito DICOM viewer. You’ll learn how to configure AE Titles, set up routing in the DCM4CHEE admin UI, and test the C-FIND and C-MOVE / C-STORE operations.
:magnifying_glass_tilted_left: What you’ll learn:
How to configure Mito for query/retrieve (C-FIND and C-STORE)
How to create a new AE Title and routing rule in DCM4CHEE
How to successfully query and retrieve DICOM studies from DCM4CHEE
MITO configuration used:
DCM4CHEE configuration:
Some written instructions here as well: Remote Application Entity · dcm4che/dcm4chee-arc-light Wiki · GitHub
How do i set autoroute to the destination AE
Hi mugwero,
so to clarify what you are asking about I think you mean how to automatically send an incoming DICOM study to an external AE in addition to storing it in the DCM4CHEE archive.
DCM4CHEE supports this behavior via Forward Rules or Export Rules in its configuration.
Here is some documentation on it:
Forwarding of received instances · dcm4che/dcm4chee-arc-light Wiki · GitHub
Does this help?
Here is a video on how to do the auto forwarding in DCM4CHEE and I also demonstrate how it works and show the export task and the results in the destination archive.
It’s a three step process to configure auto forwarding of DICOM studies in DCM4CHEE:
  1. Create a new destination AET / device
  2. create export rule
  3. create exporter / export descriptor
yes forwarding rules can you do a video on it ?
See the new auto forwarding tutorial video posted in the above post. Hope this helps :slightly_smiling_face:
this was very helpful Mr. john :saluting_face: one more question what about auto delete of images for a period of time like after one month
Glad it was helpful.
There is some documentation about retention policies here: Study Retention Policy · dcm4che/dcm4chee-arc-light Wiki · GitHub
Have you tried that already?
yes i have but its like i missed something out can you also do a guide to see if i did anything in order i would really appreciate
Excelent videos! Thank you!
Glad to hear the videos are helpful
Restrict AE Titles opening associations with Archive
It is possible to configure the Accepted Calling AE Title’s in the archive with the below guide
Using Archive UI
  1. Go to Menu->Configuration, then on Devices page, Edit the dcm4chee-arc device. Go to Child objects and select DCM4CHEE from the dropdown of Network AEs.
  2. Go to Extensions and select Edit extension of Network AE Extension and add value in Accepted Calling AE Title field and Save.
You can find further documentation here
Hi,
Episode 8 Adding users to DCM4CHEE archive 5 has been released:
Adding a user
Navigate to keycloack (replace pacs.lab with your ip or hostname)
https://pacs.lab:8843/admin/dcm4che/console
Login with root/changeit (or the password you changed it to)
Navigate to Users → user → Role mapping
You can see the roles this default user has
Go back to Users → Add User
fill in username and press create
Navigate to users → → Credentials → Set password
Next go to users → → Role Mapping and Assign Role
Replicate the roles as they were in the default user.
Be sure to check the tips on how to filter for roles in the video if you are having trouble how to find the user and auth roles
Adding users is only briefly described in the documentation for example here
“and edit, delete or add new users by navigating to Users:”
Secure Archive Users and Roles are explained here:
UI Permission Configuration is explained here
DCM4CHEE Archive User Role Permissions - Tutorial Ep 9
Permissions are explained here
One can add additional DICOM tags to be stored into the DCM4CHEE archive database via the archive device → Attribute Filter
For example adding a Study level DICOM tag can be done like this:
And then press Save.
So now if you store a study with the tag 0040,1008 Confidentiality Code it will get stored into the database in addition to just being in the DICOM file on disk.
