Please share in this topic places where you can find free to use DICOM test studies.
DICOM dataset CQ500
Yes, CQ500 is a publicly available dataset comprising 500 head CT scans, primarily used for research in medical imaging and machine learning. You can access the dataset and obtain more information through the following resources:
- CQ500 Dataset Overview: Detailed information about the dataset, including download instructions and usage guidelines, is available on the dataset’s official webpage.
- GitHub Repository: The repository provides scripts to download and process the CQ500 dataset, including converting DICOM files to NIfTI format and performing skull stripping.
Before downloading and using the dataset, ensure compliance with any usage agreements or licensing
Some DICOM test studies you can download from the dcmtk.org website
| car97cd.zip | 2002-10-15 11:38 | 301M | |
| ddsm/ | 2016-03-08 12:06 | - | |
| nema97cd.zip | 2002-10-16 12:25 | 279M |
