DICOM Test Tools
Please share your favourite DICOM Test tools in this topic.
Alexamon DICOM sender
Download link:
Platform: Windows
Features:
  • DICOM SCU C-STORE
  • Modality Worklist query
  • HL7 Send
Quick tutorial on the tools C-STORE functionality:
How to Use DVTK Modality Emulator with DCM4CHEE Modality Worklist
In the video I show you how you can use the DVTK Modality Emulator to read content from a Modality worklist and how to send DICOM images to a VNA or PACS. I also show you how you can use the DCM4CHEE Modality worklist (MWL) and how to populate an entry into it with an order message sent via the hapitestpanel tool. For a written description check my blog entry about the topic: https://openintegrator.com/how-to-use… If DICOM ECHO fails with the DVTK Modality Emulator my video and blog post also address that issue:
  • After installing and configuring the Modality Emulator you will notice that DICOM Echo doesn’t work and the log shows the following error:
  • No Command Field (0000,0100) attribute value present in DICOM command
  • No Data Set Type (0000,0800) attribute value present in DICOM command
  • This error is related to the DVTK DICOM definition files missing.
Check my blog post above for the solution
PS. I have received some emails if I have the msi installer for DVTK moddality emulator and since it’s hard to find online I did provide a zip download of the modality_emulator_3.1.4.msi inside the subscribed OpenIntegrator Memberships area of the community linked below:
https://community.openintegrator.com/t/dvtk-modality-emulator-version-3-1-4-download
How to Send DICOM Studies with DVTK Storage SCU Emulator to dcm4chee VNA
DVTK Storage SCU Emulator DVTk · Downloads
Mito DICOM Viewer MITO - DICOM Viewer download | SourceForge.net
Also Wireshark for analyzing DICOM traffic
Wireshark • Go Deep | Download
This tool is able to query and retrieve via C-FIND / C-MOVE
You can see a little bit of how to configure and use it in these two videos:
