n8n https://n8n.io/
In this guide we will use the docker-compose.yml example file from here:
Steps to install:
1. git clone https://github.com/n8n-io/n8n-hosting.git
2. cd n8n-hosting/docker-compose/withPostgres
3. nano .env
- add N8N_SECURE_COOKIE=false if you need it
5. nano docker-compose.yml
- add N8N_SECURE_COOKIE=${N8N_SECURE_COOKIE} if you need it
7. sudo docker compose up -d
The modified .env and compose files are below.
I had to add the N8N_SECURE_COOKIE=false because i’m not useing localhost and didn’t create a certificate for this example.
After installing you can access the n8n web ui at
http://localhost:5678 or instead of localhost use your ip of the docker machine
Installation guide in video format
# Basic settings
N8N_BASIC_AUTH_ACTIVE=false
N8N_HOST=localhost
N8N_PORT=5678
N8N_PROTOCOL=http
# Security
POSTGRES_USER=changeUser
POSTGRES_PASSWORD=changePassword
POSTGRES_DB=n8n
POSTGRES_NON_ROOT_USER=changeUser
POSTGRES_NON_ROOT_PASSWORD=changePassword
version: '3.8'
volumes:
db_storage:
n8n_storage:
services:
postgres:
image: postgres:16
restart: always
environment:
- POSTGRES_USER
- POSTGRES_PASSWORD
- POSTGRES_DB
- POSTGRES_NON_ROOT_USER
- POSTGRES_NON_ROOT_PASSWORD
volumes:
- db_storage:/var/lib/postgresql/data
- ./init-data.sh:/docker-entrypoint-initdb.d/init-data.sh
healthcheck:
test: ['CMD-SHELL', 'pg_isready -h localhost -U ${POSTGRES_USER} -d ${POSTGRES_DB}']
interval: 5s
timeout: 5s
retries: 10
n8n:
image: docker.n8n.io/n8nio/n8n
restart: always
environment:
- N8N_SECURE_COOKIE=${N8N_SECURE_COOKIE}
- DB_TYPE=postgresdb
- DB_POSTGRESDB_HOST=postgres
- DB_POSTGRESDB_PORT=5432
- DB_POSTGRESDB_DATABASE=${POSTGRES_DB}
- DB_POSTGRESDB_USER=${POSTGRES_NON_ROOT_USER}
- DB_POSTGRESDB_PASSWORD=${POSTGRES_NON_ROOT_PASSWORD}
ports:
- 5678:5678
links:
- postgres
volumes:
- n8n_storage:/home/node/.n8n
depends_on:
postgres:
