Originally published at: How to Install OHIF web-based DICOM Viewer in docker and connect to dcm4chee VNA - Open Integrator
OHIF is a web-based open source Medical Imaging (DICOM) Viewer. To install it on docker you can use either docker command line or for example portainer. Command line approach docker pull ohif/viewer docker run -p 3000:80 ohif/viewer:latest PS. Noticed that on 16/11/2021 the latest has some issues so you can use instead this version: docker…
