How to install portainer on a docker engine platform
The portainer community edition is free to use
First, create the volume that Portainer Server will use to store its database:
Copy
docker volume create portainer_data
Then, download and install the Portainer Server container:
Copy
docker run -d -p 8000:8000 -p 9443:9443 --name portainer --restart=always -v /var/run/docker.sock:/var/run/docker.sock -v portainer_data:/data portainer/portainer-ce:lts
By default, Portainer generates and uses a self-signed SSL certificate to secure port 9443. Alternatively you can provide your own SSL certificate during installation or via the Portainer UI after installation is complete.
If you require HTTP port 9000 open for legacy reasons, add the following to your docker run command:
-p 9000:9000
Portainer Server has now been installed. You can check to see whether the Portainer Server container has started by running docker ps:
Copy
root@server:~# docker ps
CONTAINER ID   IMAGE                          COMMAND                  CREATED       STATUS      PORTS        NAMES
de5b28eb2fa9   portainer/portainer-ce:lts     "/portainer"             2 weeks ago   Up 9 days   0.0.0.0:8000->8000/tcp, :::8000->8000/tcp, 0.0.0.0:9443->9443/tcp, :::9443->9443/tcp   portainer
Logging In
Now that the installation is complete, you can log into your Portainer Server instance by opening a web browser and going to:
Copy
https://localhost:9443
